Rembrond's avatar
Rembrond
VPNG01L - Reset Lic
Laptop where previous install located crashed. Tried doing a new install, but the netgear lic server wants me to un-install previous copy. That's not going to be possible. I see from previous posts t...
  • JohnC_V's avatar
    Jun 11, 2018
    Hi Rembrond,
    Welcome to our community! :)
    I already forwarded your license key to our engineering team and they were able to reset it successfully. It should work now.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
