Jiri_GrandPa
Feb 27, 2020Follower
VPNG05L need licence keys reset
I have replaced 4 laptops where our 5 licenses package was used, always carefully uninstalling the SW, but I am not not able to use the license on the new HW, getting error 33. Can you please help me...
- Mar 03, 2020
I got a feedback that your 5-user VPN license key has been fully reset. You may now register it again on the new laptops you have.
Since your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Feb 27, 2020NETGEAR Employee Retired
Welcome to the community! :)
Kindly send me the following below via private message:
a. the VPN license key that needs to be reset
b. e-mail address that was used when you have registered the VPN license key
DaneA
- DaneAMar 03, 2020NETGEAR Employee Retired
DaneA
