don_daniel
Oct 15, 2016Tutor
wan-to-lan speed for fvs336gv2
hi all i have a fvs336gv2 in the corner of my cave that I would like to reactive.. I am though irritated of some remarks i was rading in the net... like the favous lan-to-wan passthrough of only ...
- Oct 20, 2016
Hi don_daniel,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Oct 16, 2016NETGEAR Employee Retired
Hi don_daniel,
Yes, the LAN-to-WAN Throughput of the FVS336Gv2 is 60Mbps. You may check on the data sheet here.
Since you are subscribed with a 200Mbps of connection, I recommend that you should use a firewall router that has a LAN-to-WAN Throughput that is greater than 200Mbps. I suggest you either of the following below in replacement of your FVS336Gv2:
a. FVS318Gv2 - its LAN-to-WAN Throughput is 250Mbps
b. FVS318N - its LAN-to-WAN Throughput is 250Mbps
c. FVS336Gv3 - its LAN-to-WAN Throughput is 350Mbps
Kindly check their respective specifications on the data sheet here.
DaneA
- don_danielOct 16, 2016Tutor
thanks
what about the srx5308... should have 924mbps... is this per wan or all 4 wan's together that bring up to that speed?
same vor the fvs336gv3.... 350 it says, but this is both wan together or each wan single?
to add:
to my question applies the assumption: if only one WAN is turned on and the others are not used!
- DaneAOct 16, 2016NETGEAR Employee Retired
Hi don_daniel,
Yes, you're right! I should have included the SRX5308 since it has a LAN-to-WAN Throughput of 924Mbps.
As far as I know about LAN-to-WAN throughput, it should not divide the throughput per port.
DaneA
