don_daniel
Oct 15, 2016Tutor
wan-to-lan speed for fvs336gv2
hi all i have a fvs336gv2 in the corner of my cave that I would like to reactive.. I am though irritated of some remarks i was rading in the net... like the favous lan-to-wan passthrough of only ...
- Oct 20, 2016
Hi don_daniel,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
don_daniel
Oct 16, 2016Tutor
to add:
to my question applies the assumption: if only one WAN is turned on and the others are not used!
DaneA
Oct 20, 2016NETGEAR Employee Retired
Hi don_daniel,
DaneA
- don_danielOct 23, 2016Tutor
was solved for me.. thanks
