remltr
Dec 29, 2015Aspirant
WAN to LAN throughput FVS318G
I have a FVS318G which is 5 years old. Just got hooked up with Comcast business class. Direct connection to modem yields 85mbs wired. Via the FVS318G it is 15mbs. Can someone point me to what settin...
remltr
Dec 30, 2015Aspirant
Hi Jenn,
Modem: Cisco Model DPC 3941B
Hardware version : Not sure where to find that. Nothing shows on the 192.168.1.1 webpage or on the device itself.
Firmware: 3.1.1-18
Thanks for responding. Hope you can help me.
Dave
JennC
Dec 31, 2015NETGEAR Employee Retired
Hello remitr,
Cisco DPC3941B is a cable gateway. This means it has router capability. What WAN IP address is the FVS318G getting from the CIsco? You can give just at least the first 2 octets.
- remltrDec 31, 2015Aspirant
static ip is 173.160.xxx.9
gateway ip is 173.160.xxx.10
Hopefully that is what you are asking for.
- JohnRoJan 01, 2016NETGEAR Employee Retired
Hello remltr,
I'm joining this conversation to give more information. An FVS318G from 5 years ago is a version 1, the v1 only has a maximum WAN-LAN throughput of 22.5Mbps (based on tests). The FVS318Gv2 is the newer version that can accommodate up to 250Mbps. Given you have firewall rules configured on the FVS318G, it will really slow the throughput down. If you want to maximize the your internet speed, you may need to consider getting a newer version of the hardware.
I hope this helps, let us know if you have more questions.
Thanks,
- remltrJan 01, 2016Aspirant
John,
How do I tell the difference between a v1 and v2 on the market today. Would a v2 still be labeled FVS318G or would it be a FVS318N?
And what about a switch that would probably need replacing as well since it was also purchased at the same time as the v1 router. What would you recommend there?
Thanks,
Dave
