rsjpx's avatar
rsjpx
How to Setup Remote Desktop Connection through WAN on FVS318G
Hi,
I'm having trouble setting up outbound/inbound rules to allow for Remote Desktop Connection through WAN.  Is there some tutorial or reference guidance page that I can use?  I'm behind a 4-port modem that has one public static IP assigned to it.  I have a connected to one port the ProSafe VPN FVS318G, and it gets assiged an IP address 192.168.0.2 (which I'm somehow seeing as the assigned broadband IP).  But I there's an existing network setting that ranges from 192.168.22.1 - 192.168.22.254.
Thanks in advance,
rsjpx
  • Hi rsjpx,
    Welcome to the community! :)
    It seems that the 4-port modem you got is a combination of modem and router that is why the WAN IP address registered on the FVS318G is a private IP address.  I suggest that you set the 4-port modem to full-bridge mode so that the WAN IP address that will be registered to the FVS318G would be a public IP address.
    After you've done what I have suggested, you will need to configure an inbound rule to allow port 3389 for Remote Desktop Connection.  Kindly read pages 4-11 and  4-15 to 4-18 of the FVS318G reference manual here about LAN WAN Inbound Services Rules and Inbound Rule examples respectively.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi rsjpx,
    DaneA
    • rsjpx's avatar
      rsjpx
      Thank you DanaA!  For some reason the FVS318G didn't receive a public IP address after I had set the modem to bridge mode.  But after a couple of good hard resets to the modem, the FVS318G finally got a public IP address assigned to it.
      • DaneA's avatar
        DaneA
        Hi rsjpx,
        You're welcome! :)  I'm glad you finally got a WAN Public IP address assigned on the FVS318G.
        Feel free to post your future concerns here in the community.
        Cheers,
        DaneA
ProSupport for Business
