soosang
Feb 21, 2024Aspirant
What gbic should I use for the sfp+ port of pr60x???
I heard that the axc761 cable was compatible with pr60x, so I bought a third-party cable that was identical to the axc761, but it did not work. Also, I connected the pr60x and m4300 with several ...
BrianL
Feb 22, 2024NETGEAR Moderator
Hi soosang,
You can check this list of SFP/SFP+ modules that will work on PR60X. If the SFP/SFP+ connection to other devices such as your M4300 is broken we have to check the configuration and logs from both and even consider compatibility issues.
Kind regards,
- soosangFeb 26, 2024Aspirant
Do only Netgear products work?
I used a 3rd party product that is compatible with axc761 and axm761, but it still does not work.
- schumakuMar 03, 2024Guru - Experienced User
Supported by Netgear are only SFP and SFP+ modules explicitly listed in the official compatibility lists for the Netgear switches . In case one of these don't work, Netgear is in charge to replace or fix the devices and products affected, as long as the warranty lasts, for the original buyer. For anything else: As customers, we are on our own.
