anonymous2
Nov 03, 2011Aspirant
Wireless Guest setup via FVS336G
Greetings, I have recently upgraded our Firewall device to the FVS336G when we moved over to a T1 from DSL. Our LAN side is getting DHCP via an SBS server and the FVS336G is simply being used as the...
jmizoguchi
Nov 03, 2011Virtuoso
if you have fvs336Gv2 then use DMZ and put DLINK as AP mode . DMZ will have it's own DHCP so you do not need to use dlink as router
http://kb.netgear.com/app/answers/detail/a_id/965
if you place the port8(DMZ) then it will not associate with primary LAN until you open DMZ-LAN rules..
DMZ has it's own rules so you can limits the outbound to just http/https or whatever you decide
