anonymous2
Nov 03, 2011Aspirant
Wireless Guest setup via FVS336G
Greetings, I have recently upgraded our Firewall device to the FVS336G when we moved over to a T1 from DSL. Our LAN side is getting DHCP via an SBS server and the FVS336G is simply being used as the...
anonymous2
Nov 04, 2011Aspirant
June,
Thanks for the guidance. I set it up as you suggested and after setting the DMZ-WAN outbound rules it came up just fine. I couldn't find reference to the LAN-DMZ setting, but I left them alone (nothing entered / no modifications to FVS336Gv2 defaults) and was not able to successfully probe one LAN to the other (which is the desired result in my scenerio).
-Patrick
-Patrick
