Tamagonia
Nov 15, 2025Initiate
“WAX625/628 UI Bug: PMF Support Value Persists Between Client Detail Modals”
Hi,
This is a small UI issue I noticed on the WAX625/628 Firmware V11.8.0.9.
It’s not critical at all, but I thought it might be helpful to share in case it can be fixed in a future update.
Summary
When opening the Monitoring → Connected Clients detail modal for different clients,
the “PMF Support” value sometimes does not refresh correctly.
If the first client has PMF Support = “Yes”, and the next client is on an SSID where PMF is disabled (so the PMF row should be hidden), the modal hides the row — but the underlying DOM still keeps the previous “Yes” value.
This means the PMF Support value is carried over between clients, even when it should not appear at all.
Example (actual DOM output)
Even when PMF is disabled and the row is hidden:
*(I could not paste the raw HTML here because the forum rejects posts containing HTML tags, so I attached an image instead.)*
Impact
- Very minor UI issue
- Can cause incorrect values to be read if automating the UI or parsing the DOM
- Not visible to regular users
- Again, nothing critical — just a small inconsistency.
Steps to reproduce
- Open Connected Clients
- Open detail modal for a client with PMF Support = Yes
- Close it
- Open detail modal for a client on an SSID where PMF is disabled
→ The row hides, but the value stays “Yes” internally
Expected
The PMF Support element should clear or refresh when switching clients.
If this could be cleaned up in a later firmware/UI update, that would be great.
Thanks for maintaining the product — overall the WAX625 and WAX628 has been very stable in my environment.
No RepliesBe the first to reply
