WexyR
Feb 13, 2021Follower
192.168.0.100 not responding on WAC104
Hello there ! I've an issue with my wac104 .. I lost all the information about it so I reset it and wanted to follow the installation steps in the manual. But when it comes to go to 192.168.0.100...
DaneA
Feb 17, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly try to disconnect the WAC104 from the existing network. Then, connect a PC directly to the WAC104. Be sure to set a static IP address on the PC that is within the IP address range of the WAC104. Check if you can get replies when you ping the IP Address of the WAC104. If you are getting replies, follow the steps in the article below:
How do I install my WAC104 access point?
DaneA
NETGEAR Community Team
