Little-JB
Sep 07, 2022Aspirant
access point WAC124
Hi Community, First off i'm clueless with anything like this so any answers in simple to follow instructions please lol. I have a BT router in my house which i've ran a cat6 cable from to a garden ...
Sep 07, 2022Guru - Experienced User
You can simply connect an access point.
You'll still need to go through the setup process but it isn't complicated.
That'd let you set the same ssid/password as the main home.
You'd just want to make sure to have the access point on a different wireless channel so if it does reach the house, it isn't creating interference with the home's wireless network.
Little-JB
Great, Thanks for the prompt reply.
