Lascar77
Dec 17, 2022Aspirant
Accessing Interface WAC104
Hi i just got an new WAC104 access point, and i cannot by any means i know access it's interface. The proposed guide in the box does not work. Using my knowledge of manual setup i used on previous ro...
michaelkenward
Dec 17, 2022Guru - Experienced User
What happens when you try? Unfortunately, "does not work" could mean many things.
I have even changed my home router host i.p and assigned static ip to my mobile or pc to gain access but that also does not work.
What is that home router and the other stuff on your network?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Lascar77
As i have said above, i have tried everything. And it means everything. I will try the other sections thanks
- schumakuDec 17, 2022Guru - Experienced User
everything? ... lool, sorry.
At the risk of disapponting you https://community.netgear.com/t5/Business-Wireless/Accessing-Interface-WAC104/m-p/2280772/highlight/true#M10248
- michaelkenwardDec 17, 2022Guru - Experienced User
Did that include running around naked at midnight in the winter solstice?
It certainly didn't include answering the questions I posed.
Michael, you made my day!
