Spindlebackcat
Dec 19, 2021Tutor
Assign SXK30 Phillips Hue ethernet to a specific wifi network
Hello, Apologies if this is obvious - is there a way to assign the Phillips Hue I have plugged into a particular network, i.e. my IOT network? Works fine on the default admin network, but want to...
Dec 19, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
- michaelkenwardDec 20, 2021Guru - Experienced User
Where did Orbi come from?
Good idea to read messages before you hit the boilerplate button. Or at least ask a useful question.
- FURRYe38Dec 20, 2021Guru - Experienced User
SXK = Orbi Pro.
https://www.netgear.com/support/product/sxk30.aspx
