Spindlebackcat
Dec 19, 2021Tutor
Assign SXK30 Phillips Hue ethernet to a specific wifi network
Hello, Apologies if this is obvious - is there a way to assign the Phillips Hue I have plugged into a particular network, i.e. my IOT network? Works fine on the default admin network, but want to...
michaelkenward
Dec 20, 2021Guru - Experienced User
Spindlebackcat wrote:
Hello,
Apologies if this is obvious - is there a way to assign the Phillips Hue I have plugged into a particular network, i.e. my IOT network? Works fine on the default admin network, but want to shift it off that if possible.
Probably best addressed by Phillips.
Heaven only knows why anyone would use their boilerplate text to tell you to post in the Orbi section. I see no hint that you are using an Orbi device. Maybe you are using a Nighthawk router.
In any case, asking that question somewhere else isn't likely to get a different answer. This is a generic question that applies to any router with a guest network.
Can you reset the Hue and set it up from scratch?
