Spindlebackcat
Dec 19, 2021Tutor
Assign SXK30 Phillips Hue ethernet to a specific wifi network
Hello, Apologies if this is obvious - is there a way to assign the Phillips Hue I have plugged into a particular network, i.e. my IOT network? Works fine on the default admin network, but want to...
michaelkenward
Dec 20, 2021Guru - Experienced User
FURRYe38 wrote:
Netgear has set up a community forum specifically for the Orbi Pro products.
Where did Orbi come from?
Good idea to read messages before you hit the boilerplate button. Or at least ask a useful question.
SXK = Orbi Pro.
https://www.netgear.com/support/product/sxk30.aspx
