Spindlebackcat
Dec 19, 2021Tutor
Assign SXK30 Phillips Hue ethernet to a specific wifi network
Hello, Apologies if this is obvious - is there a way to assign the Phillips Hue I have plugged into a particular network, i.e. my IOT network? Works fine on the default admin network, but want to...
Dec 20, 2021Guru - Experienced User
Spindlebackcat wrote:
Hello,
Apologies if this is obvious - is there a way to assign the Phillips Hue I have plugged into a particular network, i.e. my IOT network? Works fine on the default admin network, but want to shift it off that if possible.
You're using the SXK30?
The SXK30 has an IoT network as part of its multiple ssid's for the pro line. You can simply enable that ssid and migrate the hue over to it.
And you should be able to assign one of the vlan's for the ethernet connection to a hue hub that works with the IoT ssid.
Is that what you're asking? or what issue are you running into setting it up.
Spindlebackcat
Dec 23, 2021Tutor
Oh dear - sorry everyone, I didn't spot there was an Orbi forum.
Basically Plemans exactly that - I can see I can add an 'iot' vlan profile to the lan port- but I thought that added some rules about what could and couldn't connect, rather than identify the wifi network it's going to use.
I'm really not sure how clear I'm being - so apologies in advance. Maybe I should just have a better play in the menus.
