Thor33
Jul 15, 2023Follower
AX1800 LED Brightness
Is it possible to diminish the brightness of the LED’s on AX1800 ? Or, is it possible to have all LED’s off between 10am and 8am without effecting performance of the box ?
schumaku
Jul 15, 2023Guru - Experienced User
Very unclear what AX1800 you are talking of here. Find the exact model (printed on the label) and locate the user manual on https://www.netgear.com/support/
The RAX10 and RAX20 (and probably others) show a control to "Turn off the router LEDs", here from the RAX20 User Manual, p.103. Not on a schedule however.
