Thor33
Jul 15, 2023Follower
AX1800 LED Brightness
Is it possible to diminish the brightness of the LED’s on AX1800 ? Or, is it possible to have all LED’s off between 10am and 8am without effecting performance of the box ?
Jul 16, 2023Guru - Experienced User
Is this a WAX model?
- nmhTesterJul 26, 2023NETGEAR Employee Retired
for WAX610 (or any WAX600 series). There is easy way to turn ON-OFF LEDs. you can even control which LED to turn on/off/on.
example
all LEDSall LEDS except power LED.
you can do it via local UI (in standalone mode and via Insight (for multiple APs at a time).
