martinav
Sep 03, 2018Guide
Bad environment detected on Radio[0]:Channel[11] by AP Garage - WAC740
I am getting this error. Not sure why. Sometimes it goes down, sometimes it does not. Is it RF? Temperature? It is outside (well, in a garage, safe from elements... but not controlled), and curr...
- Nov 08, 2018
It is clear for your Neighbour AP list that Channel 1, 6 and 11 are congested & the behaviour is expected in this kind of condition.
Below is the details shows that how many ap's are configured to a particular channel:
Channel-1 has configured with 17 AP's, 6 has configured with 10 AP's and channel-11 has configured with 13 AP's and all these are non overlapping channels so you left out with overlapping channels
You can select any channel from these 2,3,4,5,7,8,9,10, and make sure you use different channel for each AP.
RaghuHR
Nov 09, 2018NETGEAR Expert
Are you saying only with HPE Aruba 3810M our WAC740 is not powering via PoE? Are you using different switch for your previous setup?
Thanks,
Raghu
martinav
Nov 09, 2018Guide
I changed the switch yesterday. I have been powering all APs with the Netgear 12V 2.5A adapters since I changed out the WAC730s for the 740s. The WAC730s powered via PoE just fine. I will address this only after I have confirmed resolution with the AP channel issue.
My Previous switch was an HPE 1920 switch.
Thank you.
