KGA20
Feb 04, 2020Aspirant
Block client device connected to wifi
when I access to Insigth Cloud Portal I can see a list of connected clients to my wireless network but I can not block access to a SSID or all network How can I do that?
- Feb 05, 2020
Welcome to the community! :)
I suggest you to enable MAC Access Control so that you can allow devices with known MAC addresses to connect to the SSID. Kindly access the article below and follow the steps indicated:
How do I set up a WiFi MAC access control list (ACL) in Insight?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Feb 05, 2020NETGEAR Employee Retired
DaneA
