GordnFreeman
Mar 12, 2018Aspirant
[Bug] Daylight Saving time Implementation
Model: WAC730 ProSAFE Dual Band Wireless AC Access Point Firmware: 3.7.11.0 Appearently the offset of the Daylight saving time is not always adjusted correctly regarding specific timezone differ...
- Mar 13, 2018
Hi GordnFreeman,
Welcome to the community! :)
I suggest you to upgrade the firmware of your WAC730 to the latest version which is v3.8.3.0. One of the fixes include showing proper time based on time zone configured during DST period. You can download firmware v3.8.3.0 here.
Be reminded to perform a factory reset to your WAC730 after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Observe if same problem will occur.
DaneANETGEAR Community Team
DaneA
Mar 13, 2018NETGEAR Employee Retired
Hi GordnFreeman,
DaneA
RaghuHR
Mar 14, 2018NETGEAR Expert
GordnFreeman Are you able to update to latest 3.8.3.0 firmware and see your time is correctly updated?
Thanks,
Raghu
