RaulitoH's avatar
RaulitoH
Follower
Feb 17, 2022
Can we copy all settings from a wireless device to another? WAX610
Hello everybody,
We have a few WAX610 Wireless working in our network with a special configuration; VLAN, Windows Login, etc.
Now I would like to add to more devices with the same configuration, is it possible to copy all the settings from the already configured devices into a file and then copy it into the new ones? would it work?
Thank you very much for your help!!
Regards
RaulitoH
1 Reply
  • schumaku's avatar
    schumaku
    Technically, you could copy the config to many more WAX610 - same model required.
    Honestly, I would reconfigure the same setting on Insight (little bit vague what you mean with the Windows login). Now you can simply add more APs with the same config for the same network. Very easy to add more WAX620, WAX630, .... again with the same config. last but not lest, Insight would allow changing the config, update the PSK on an SSID, add additional VLANs and SSID, ... and much more.
ProSupport for Business
