andrewki's avatar
May 29, 2024
Can you extend the wifi signal of a WAX610 with an AX1600 Wifi Extender
Hello, I am trying to set up an AX1600 as a wifi extender to my closest Wax610 access point. The nighthawk app finds the Wax610 powered network ok (both 2.4 and 5) but when I enter the passwords (sam...
  • andrewki's avatar
    andrewki
    May 30, 2024
    Apologies I posted it here in case the issue was with the Wax610 configuration. But yes it has worked fine setting it up with the browser rather than the app - case solved!
    Andrew
ProSupport for Business
