andrewki
May 29, 2024Guide
Can you extend the wifi signal of a WAX610 with an AX1600 Wifi Extender
Hello, I am trying to set up an AX1600 as a wifi extender to my closest Wax610 access point. The nighthawk app finds the Wax610 powered network ok (both 2.4 and 5) but when I enter the passwords (sam...
- May 30, 2024
Apologies I posted it here in case the issue was with the Wax610 configuration. But yes it has worked fine setting it up with the browser rather than the app - case solved!
Andrew
andrewki
May 30, 2024Guide
Thank you!
But the nighthawk app finds the Wax610 powered network ok (both 2.4 and 5) but when I enter the wifi password in the nighthawk app as part of setup (same for both), it comes back with 'Incorrect Password'. I have tried it with mesh turned on and off in the Wax610. Anything I need to set differently on the Wax610?
schumaku
May 30, 2024Guru - Experienced User
The Insight Instant Mesh config is just required for adding additional WAX6xx as a wireless "satellite".
- andrewkiMay 30, 2024Guide
Thank you. Yes I understand that but I am trying to add an AX1600 extender to my Wax610 (not another Wax610) which you seemed to indicate would work ok, but it does not let me add it to the Wax610 powered wifi network.
- schumakuMay 30, 2024Guru - Experienced User
Wrong SSID selected? Wrong security? Wrong PSK (wireless key)? Already tried the Web based config for the Extender instead of hope and pray in an App? Configured the extender in Mesh mode allowing to duplicate the same SSID and security settings, or have tried to configure a classic xyz-EXT SSID on the extender?
The point is we're on the Business Wireless community section here, and last but not least I'm not Netgear and do t have any current experience with these consumer extenders. Sorry.
Andrew
