lannyho
May 16, 2017Aspirant
Cannot get custom field value in WAC720 captive portal
Hi, I bought a WAC720 for guest wifi testing, I want to install my cafe and provide a free wifi access, before free wifi access, the customer need to provide their mobile no.. After hardware installa...
- May 16, 2017
Hi lannyho
I assume you are managing WAC720 with Business Central. Once user gets authenticated with captive portal then go to monitoring page and under CP session tab you can download all the custom fields in csv format. See the attached sample screen shot for your reference.
Let know if this is what you are looking?
Thanks
Raghu
RaghuHR
May 16, 2017NETGEAR Expert
Hi lannyho
Thanks
Raghu
lannyho
Thanks your solution, however, can I restrict user to input correct type of mobile no., for example, at least 8 digital number?
- RaghuHRMay 16, 2017NETGEAR Expert
Since it is a customer field we have made no restriction. But having said that we can think this in our next releases.
Thanks for your feedback
- Nov 30, 2019Retired_Member
