ITiBronx
Jul 16, 2021Aspirant
Cant connect to Netgear WC7600V2 default IP 192.168.0.250 after changing the management vlan
Hi, I am new for this and I was testing the vlan in the wireless controller. I wrongly set the management vlan from 1 to 2. Now i cant connect back to my wireless controller using the ...
- Jul 16, 2021
Depends on the environment ... using a switch with a port connecting a computer with VLAN 2 [U]ntagged, PVID 2, and another port connecting to the controller with VLAN 2 [T]agged. Voilà, now you have a simple a VLAN 2 management network.
schumaku
Jul 16, 2021Guru - Experienced User
ITiBronx
Jul 17, 2021Aspirant
Thank you so much. Now i can login again.
