rallyboy's avatar
rallyboy
Follower
Jan 24, 2022
Connect access points to a Mesh System
I own a mesh system AX6000 Tri-Band Orbi Pro with 4 add-on satellites (total of 5 devices) and its working greatly. I was wondering whether I could expand my coverage further with Access Points such as AX3600 or AX6000.
If thats possible, do I simply connect the AX3600 with Power Adapter directly on any of my Satellites and it works or do I need anything else?
1 Reply
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    rallyboy
    Welcome to the community!
    Not sure what model you're referring to but the SXR80 which you have is only compatible with the satellite SXS80.
    But if you're referring to access points such as the WAX620, then it should work with the Orbi Pro system by just following the installation guide here.
    JeraldM
    NETGEAR Community Team
ProSupport for Business
