alxkkbrg
Oct 24, 2021Aspirant
Connecting a Netgear WAX630 AP (30,1W) to a Netgear GC510P (POE+ or 802.3at or 30W MAX)
Hi everyone-- It seems I bought the wrong switch :( My setup regarding my question is me using a WAX630 access point and a Netgear GC510P POE+ switch. Since the power consumption of the AP always w...
- Oct 25, 2021
Well, almost fine. They still keep the door open to state the possibly limited to 30W at the PSE (or just 25.5W at the PD on the maximum cable lenth) can lead to a preformance or functionality limitation. It's a little bit more than just the .1W FWIW.
schumaku
Oct 25, 2021Guru - Experienced User
Hi Alex,
In my understanding and as discussed with Netgear product management and engineering - you see you are not the only one confused by these messages - the switch PSE will power the PD, the WAX will boot and run normally under most operation states if powered "just" from a 802.3at PSE. There is a small risk that the PD can draw more power than the 802.3at can supply, what would lead to a crash and restart. There is however no reduced power available for the typical operations, eg. the radios will operate at the full speed.
Now most PSE can supply a little bit more power than the theoretical 802.3at limit implies. And you might not hit any issue. If you don't push the switch (the PSE) to it's power budget limits, the risk is overseeable. And that's why Netgear allows this overdraft, and does not enforce the requirement of a 802.3bt PSE - this would prohibit powering from a 802.3at PSE.
As long as you don't exceed four WAX630, the GC510P with it's 802.3at PSE ports providing 4 x 30.1W max you will be still within the power budget of 134W (from wally brain). While Netgear allows powering the WAX630 from a 802.11at PSE port, there is no guarantee each PSE and PD combination is be workable.
If you want to be on the "correct" side of the IEEE PoE specs, think about a PoE++ switch. When pushing things to the max, say you choose a Netgear MS510TXUP eight Ultra60 PoE++ ports with 295W PoE budget to drive eight WAX630 you see that you will be well within the specs for the PD as well as the PSE.
-Kurt
alxkkbrg
Oct 25, 2021Aspirant
Hi Kurt--
Thanks for the quick reply. So sum up if I understood your reply correctly:
1. The message of the Netgear AP's GUI is incorrct.
2. The AP is not reduced in performance or throughput when connecting to "just" a POE+ class4, 802.3at switch which only supports 30W max.
3. If AP hits the power limit of 30W+ and will reboot, one should consider to buy a more powerful POE++ switch (e.g. models suggested by you).
In other words: "ignore the message, you are fine!". Is that it? Does that sum it up?
Thanks and best wishes,
Alex
- schumakuOct 25, 2021Guru - Experienced UserYes, exactly!
