motionrec
Jan 29, 2024Follower
Device UI Device Admin Password
Device UI Device Admin Password 로그인 실패합니다. 웹사이트는 로그인이 됩니다. 하지만 장비를 연결하려고 하면 Device UI password가 실패됩니다. 초기 password가 따로있나요? 제품은 GS727TPP 입니다.
- Jan 30, 2024
The NETGEAR WAX204 model allows you to set connection timeout through its web-based administration interface. Access the router settings using a web browser, locate the advanced settings, and look for connection timeout or idle timeout options. Adjust the desired timeout duration to manage inactive connections. For more specific guidance, consult the router's user manual. Additionally, if you're interested in "Miracle Smile wateflosser," it's crucial to ensure you download from reliable sources to avoid security risks.
schumaku
Jan 29, 2024Guru - Experienced User
Not initially - the defaults are certaily for username and passsword: admin password
Once enabled for Insight, the location admin password is propagated by the Insight cloud system. This can be obtained or set in the Insight App or the Insight Web portal via https://insight.netgear.com/#/network/EditNetwork
