DeFlanko's avatar
Sep 01, 2024
Devices from AP to AP results "Bad Password"
I have a weird on going issue that im hoping someone can help with.   I have two Access points in the home, one upstairs (WAX615 on ch3 / ch36 ) and one downstairs (WAC510 on ch1 / ch161) Both are...
  • DeFlanko's avatar
    Sep 01, 2024
    I think i may have just solved my own issue.
    On each of the SSID's i didnt have "Fast Roaming (802.11r)" enabled. (and 802.11k/v)
    Once I turned that on, it appears that the hand off between AP's is working again.
    ... not sure when that was turned off.
ProSupport for Business
