rovo
Jun 02, 2022Tutor
Disabled Insight but still being monitored by Insight Cloud
Hello, I have a few WAC510 devices. I tried them out on the Insight Managed Cloud, but after some trial, I determined it wasn't for me. I removed them all from the Cloud Admin and switched the APs ba...
- Jun 03, 2022
Hi rovo
From Insight Engineering team, we tried this and couldn't see same behavior that continued to trouble you. Do you still remember your Insight account email? If you could do that, and/or email insight-feedback <[email protected]>, we can continue from there. Thanks for being patient.
rovo
Jun 02, 2022Tutor
Thanks JeraldM
I have not tried restoring to defaults. I was worried about losing all my settings, but I will try that out and let you know how it goes.
I did follow the steps in the two links you provided for removing the devices, and when viewing the Cloud Management, there are none listed and no locations defined either.
So it sounds like the last resort is to just set back to factory...
ycNTGR
Jun 02, 2022Initiate
Hi rovo
Could you confirm whether you're getting the AP offline email notification:
- only right after you removed device from Insight account, or
- continue to receive the email notification when is already locally-managed, and then goes online/office
Thanks.
- rovoJun 02, 2022TutorycNTGR
I had removed the devices and disabled insight managed several months ago. I get the email notification anytime I reboot the AP or reboot my router.- ycNTGRJun 03, 2022Initiate
Hi rovo
