danpool
Jan 12, 2017Aspirant
Do I have the WC7600v1 or WC7600v2 ??
Hey, We have 10 WNDAP660 Access Points connected to one WC7600 controller. Unfortunately, the conection cuts out for half a second every 5 minutes (noticable only when streaming). This is rid...
- Mar 13, 2017
Hi,
I had gone through the logs, and figured that the issue could be because of the AMPDU, is it ok to disable AMPDU and observe the behavior. Disabling the AMPDU will decrease the over all througput of the AP, but it will improve the reliability. If possible make this change and observe the network.
DaneA
Mar 12, 2017NETGEAR Employee Retired
It will be posted soon on the WNDAP660 Firmware and Software Downloads page here.
DaneA
NETGEAR Community Team
LaxmankumarG
Mar 13, 2017NETGEAR Expert
Hi,
- danpoolMar 13, 2017Aspirant
Cheers dude.
I've disabled that. I'll let you know how it goes :)
I think you've done it!
Works well now.
Thank you :)
- DaneAMar 16, 2017NETGEAR Employee Retired
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- danpoolMar 16, 2017Aspirant
No worries, I've marked it.
