ITiBronx
Jul 16, 2021Aspirant
Cant connect to Netgear WC7600V2 default IP 192.168.0.250 after changing the management vlan
Hi,
I am new for this and I was testing the vlan in the wireless controller.
I wrongly set the management vlan from 1 to 2.
Now i cant connect back to my wireless controller using the same default ip 192.168.0.250.
Is there any solution to connect back without factory reset the wireless controller.
Thank you.
Depends on the environment ... using a switch with a port connecting a computer with VLAN 2 [U]ntagged, PVID 2, and another port connecting to the controller with VLAN 2 [T]agged. Voilà, now you have a simple a VLAN 2 management network.
- ITiBronxAspirantThank you so much. Now i can login again.
