bbriner
May 23, 2018Aspirant
Does the WAC505 support 802.11d outside of USA?
Does the WAC505 support 802.11d (country information in the beacon) for units sold outside of the USA?
- DaneANETGEAR Employee Retired
- bbrinerAspirant
Thank you for the answer but the manual does not mention if the WR505 broadcasts the country information in the beacon (802.11d).
The issue is that my MacBook Pro finds a wifi in the neighborhood with "China" and adjusts itself to the chinese channels. The only way I found to overcome the problem is to put my R7000 running Tomato to broadcast my correct region. As the R7000 is stronger than my the one broadcasting "China" my MacBook Pro adjusts itself correctly.
Can you please clarify if the WR505 broadcasts or has the option to broadcast the country information ?
