DeNeil's avatar
DeNeil
Email Settings for syslog not saving - WC7500
Email Settings for syslog not saving - WC7500 - tried different browsers - cleared cache - entered details - hit apply - looks ok - navigate away - come back - it has reverted to asterisks. Any ideas...
  • DaneA's avatar
    DaneA
    Sep 11, 2022
    DeNeil,
    Thank you for your response. 🙂
    I suggest you to update the firmware from v6.5.3.9 to v6.5.5.24 then check if the same problem will occur.  You can download WC7500 firmware v6.5.5.24 here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
