klimchuk
Feb 08, 2021Aspirant
CAX80 doesn't save settings
I just found that my CAX80 lost password after reboot, password works after change until next reboot
But newly create port-forwading doesn't work at all even though it's listed in UI, new port forwarding is gone from UI after reboot too
What can I try to fix it?
Firmware
V2.1.1.4
What browser are you usuing? Try IE11, Edge, Firefox or Opera
- klimchukAspirant
Thank you for reply!
Eventually I did factory reset and now it's working fine.
It was pain to get all custom configuration back though
Make sure you do a back up configuration to file for safe keeping. Saves time if a reset is neede. Please mark your thread as solved so others will know.
Enjoy.
