bunmiade
Oct 03, 2022Aspirant
Equipment Recommendation - 20 apartments
Hi, I have 20 apartments for which I would like to provide internet. The plan is to buy two Startlink Internet connections and distribute the signal across the 20 apartments. Each apartment...
schumaku
Oct 04, 2022Guru - Experienced User
bunmiade wrote:
What equipment(s) is recommended to connect to the two starlink ISP routers and distribute to all 20 apartments. Each apartment to have it's own username and password.
Designing and implementing a basic distribution network is comparably simple. In general, I suggest to avoid any experimenting with wireless mesh type implementations.
To build a simple LAN using Ethernet in some hub-and-spoke config is basic. Considering what's available these days https://www.ookla.com/articles/starlink-hughesnet-viasat-performance-q1-2022 a simple Gigabit Ethernet, even if sharing two Starlinks, looks fine as of writing. but things can change very quick.
Challenges start with having to (or more) Internet connections for most users. You need a router to combine these Internet (WAN) connections, able to apply some load distribution and connection/bandwidth availability, apply bandwidth limitations to the individual apartments and/or concurrent users. You might want to target a single LAN with a single IP subnet ideally for user-friendliness..
Think about the fact that Starlink is nice for some areas, however, the available average bandwidth is limited. Especially if you compare to what decent Wi-Fi can provide. Current essential Wi-Fi 6 AP demand 2.5 Gigabit Ethernet LAN connections to be able to cover the Wi-Fi 6 bandwidth alone.
