Paderborner
Oct 25, 2017Aspirant
Firmware download for WAC104
Hello! I tried to download the last Firmware oft the Wifi-router WAC104 from this page, but i didn't find any download button nor the download started: https://kb.netgear.com/000049507/WAC104-Fi...
- Oct 26, 2017
All,
We have corrected the link. Could you please re check?
Thanks
Raghu
antinode
Oct 25, 2017Guru
> this page, [...]
How did you get to that page?
> [...] but i didn't find any download button
That may be normal for a KnowledgeBase atricle. On the right side, I
saw a useful link under "This article applies to:". Generally, I'd
suggest: Visit http://netgear.com/support , put in your model number,
and look for Downloads.
Paderborner
Hi antinode,
Thanks for your quick answer!
i found the site via the site search on top of the site.
So, i am gonna wait for the download-link on the page for the upgrade.
Thank you!
- antinodeOct 25, 2017Guru
The built-in search on Netgear's site is sub-ideal.
It's your decision, but if you're waiting for a change on the
KnowledgeBase article page, then you may be in for a long wait. It
already has a link to the product support page:
https://www.netgear.com/support/product/WAC104
which offers links to the firmware kits. Or:
> [...] Visit http://netgear.com/support , put in your model number,
which leads to the same place.- RaghuHROct 26, 2017NETGEAR Expert
All,
Thanks
Raghu
- PaderbornerOct 26, 2017Aspirant
Hello Raghu,
the download-link worked.
Thank you!
