shiekh
May 27, 2016Guide
FVS318N; FVS318Gv2 Firmware 4.3.3-8
Firmware 4.3.3-8 was just released for the FVS318N and FVS318Gv2 (I have both) * The FVS318N works for 5 mins only (this has not changed from 4.3.3-6) * The FVS318Gv2 finds 4.3.3-8 invalid or...
- May 30, 2016
i got the same error message on fvs318gv2 but i was able to upgrade via tftp and telnet.
util firmware_upgrade <filename> <tftp server>
but i think this is not the recommended way!?
edit: i don't know if any of my problems are fixed now?! (freezes, not responding, ...)
shiekh
Jun 10, 2016Guide
What is really weird is that my old
FVS336Gv2 works great on firmware 4.3.3-6
yes, I know, I have far too many firewalls; makes me wonder if the code is good but the compilers not...
rickgode
Jun 18, 2016Aspirant
UHG... Please help... I was hoping that this 4.3.3-8 Firmware would help keep my FVS318Gv2 from "Hanging" see this post. But it looks like 4.3.3-6 doesn't allow updating the firmware from the web, see same post. They said maybe try reloading the firmware, but it always said "the file was invalid or corrupted" even when I tried to reload 4.3.3-6 (my current firmware)
Fast forward to today when I saw that the firmware had been updated to 4.3.3-8. I was excited, but like the OP it said that the "Firmware file is invalid or corrupted"
I came across this thread and solution, so I downloaded Solarwinds TFTP server and put the FVS318Gv2_v4.3.3-8.img in the TFTP's root folder, then I fired up Putty so I could telnet into the router. Everything looked fine, easy peasy...
Below is what it sort of looked like... I took the text from this post (I realize that it says v4.3.3-6.img, but in putty everything looked pretty much exactly like this, but it wouldn't finish the rest of it. Putty would crash and the window would disappear.)
FVS318Gv2> util firmware_upgrade FVS318Gv2_v4.3.3-6.img 192.168.1.4
FVS318Gv2_v4.3.3-6.i 100% |*************************************************| 26224k --:--:-- ETA
chmod: /mnt/tmpfs/tr69Instance.map: No such file or directory
Start upgrade ...
/var/image/FVS318Gv2_v4.3.3-6.img length is 0x199c000(26853376)
filename : ASL firmware
filelen : 0x199bf00
filecrc : 0x19d79729
file version : 4.3.3-6
kernel offset : 0x100
kernel size : 0x7c2272
fs offset : 0x8fff00
fs size : 0x109c000
I tried a couple more times, then switched computers and each time Putty would crash, but each time I was able to login via the web, until the last attempt... Now I believe I've bricked the router... The test light just stays on and no matter how long I press the reset button on the back, nothing changes...
My FVS336Gv2 works great on firmware 4.3.3-6 too. In fact, it's the only reason I have internet at home now... It just doesn't have the WAN throughput that I need.
Please advise.
Ricky
- shiekhJun 18, 2016Guide
While it does not help you, I did my tftp from a Mac, even though my main machine is now a PC; I think you will need to send it back on lifetime warrentee.
It is hard to belive that issuing such firmware does not tarnish the reputation of Netgear, and I now use a ZyXEL VFG6005N firewall while waiting for Netgear to offer a workable version.
I figured out that booting the unit with just the WAN connected and then connecting the rest later would result in things working indefinitely, but I need a solution that can recover itself from a power cut.
- shiekhJun 19, 2016Guide
https://community.netgear.com/t5/VPN-Firewalls/FVS318Gv2-WAN-to-LAN-throughput/td-p/1020400/page/3
gives more detail on the output, but by running blind I imagine you may not have given it enough time to complete;
however none of this is very useful at this point.
Start upgrade ...
filelen : 0x199bf00
fs size : 0x109c000
calculate crc is : 0x19d79729
crc check PASS
Writing File System to Flash ...
Done.
Writing Kernel to Flash ...
Done.
>Firmware Version Updated- rickgodeJun 19, 2016Aspirant
Thank you. I came across that post yesterday too.
I have to tip my hat to Netgear Support. The test light just stays on, so I called the number and they will be sending me one this week. Good thing I kept my old FVS336Gv2 or my household would have revolted!
Ricky
It actually works for you? Tell me the magic; for me it works for 5 mins and then just stops... so my FVS318N abd FVS318Gv2 just sit awaiting the next firmware in the hope that will fix the issue. 4.3.3-8 was more challenging than usual to install (as you found out), but even then the units went back into storage as it did not fix the 5 min issue.
