eratichomeowner
Aug 04, 2022Tutor
GS108PEv3 to WAX214 not providing internet
Hello everyone! I have a GS108PEv3 POE unmanaged switch set up. It receives internet from verizon FIOS and I can access the management page and see that the connection to the router is 1GBPS. ...
- Aug 11, 2022
JeraldM Thank you for your follow-up!
I just wanted to update you: basically the end of the ethernet cable was no functional (a couple of wires had connection issues). This is what made the WAP see the connection as "10 MBPS" . The contractors (with a big ladder) came back and fix those cables that are running in the walls. Now the WAP sees "1GPBS" and the Netgear switch is all green led!
It was just weird luck that the cable was messed up enough to not provide internet, but still functional enough to provide power to the WAP.
Thank you!
Aug 04, 2022Guru - Experienced User
What happens if you directly connect the AP to the Verizon gateway?
eratichomeowner
Aug 04, 2022Tutor
Unfortunately my FIOS G3100 does not support PoE and my WAP are only connected to the ethernet not a power adapter (they are set in the ceiling and I don' t currently have a way to take them down.)
