eratichomeowner
Aug 04, 2022Tutor
GS108PEv3 to WAX214 not providing internet
Hello everyone! I have a GS108PEv3 POE unmanaged switch set up. It receives internet from verizon FIOS and I can access the management page and see that the connection to the router is 1GBPS. ...
- Aug 11, 2022
JeraldM Thank you for your follow-up!
I just wanted to update you: basically the end of the ethernet cable was no functional (a couple of wires had connection issues). This is what made the WAP see the connection as "10 MBPS" . The contractors (with a big ladder) came back and fix those cables that are running in the walls. Now the WAP sees "1GPBS" and the Netgear switch is all green led!
It was just weird luck that the cable was messed up enough to not provide internet, but still functional enough to provide power to the WAP.
Thank you!
JeraldM
Aug 08, 2022NETGEAR Employee Retired
Hi eratichomeowner,
It is somewhat weird that you're getting 200Mbps download speed on your desktop even though it indicates a 100Mbps connection on the switch's port LED.
By any chance, do you have a spare PoE switch or a PoE injector to connect it to the WAX214?
JeraldM
NETGEAR Community Team
eratichomeowner
Aug 11, 2022Tutor
Thank you!
- plemansAug 11, 2022Guru - Experienced User
Glad to see it was a bad end of the wire and not a hardware issue!
Thanks for updating us!
