Cartier
Jul 26, 2024Apprentice
Guest network
Hello everyone, I ask for help if it is possible to create a guest network with this access point, via NETGEAR Insight??? Thanks for the help. Access Point WiFi 6 AX1800 WAX610
- Jul 27, 2024
Yes, this makes about sense.
Don't be confused that all Insight managed AP are - for this giest network - local, private RFC1918 IP addresses, and the SSOD won't allow seamless roaming.
schumaku
Jul 27, 2024Guru - Experienced User
What expectations, and more what environment (like a multi-VLAN and IP-subnet capable router) you have in place?
The minimum implementation .- in absence of a VLAN-capable router - would be to define a new SSID and security for guest Internet access plus NAT mode where each WX6xx or WBE7xx will do a many2one NAT to the AP LAN interface. This means the guests won't be able to communicate on the local LAN and subnet..
Cartier
Jul 27, 2024Apprentice
Hi thanks for the reply, I configured the guest network as you see in the photo, do you think it can work??? Thanks
- CartierJul 27, 2024Apprentice
- schumakuJul 27, 2024Guru - Experienced User
- CartierJul 28, 2024Apprentice
thank you very much and have a nice day
