Cartier's avatar
Cartier
Apprentice
Jul 26, 2024
Guest network
Hello everyone, I ask for help if it is possible to create a guest network with this access point, via NETGEAR Insight??? Thanks for the help.   Access Point WiFi 6 AX1800 WAX610
  • schumaku's avatar
    schumaku
    Jul 27, 2024
    Yes, this makes about sense.
    Don't be confused that all Insight managed AP are - for this giest network - local, private RFC1918 IP addresses, and the SSOD won't allow seamless roaming.
ProSupport for Business
