Cartier
Jul 26, 2024Apprentice
Guest network
Hello everyone, I ask for help if it is possible to create a guest network with this access point, via NETGEAR Insight??? Thanks for the help. Access Point WiFi 6 AX1800 WAX610
- Jul 27, 2024
Yes, this makes about sense.
Don't be confused that all Insight managed AP are - for this giest network - local, private RFC1918 IP addresses, and the SSOD won't allow seamless roaming.
Cartier
Jul 27, 2024Apprentice
Hi thanks for the reply, I configured the guest network as you see in the photo, do you think it can work??? Thanks
