SighaticaPillow's avatar
Dec 06, 2020
Home LAN
I have a house that in notoriously WiFi unfriendly.  I am setting up new hardware while I paint the interior, makes it easier to patch and then paint.  I am waiting on some pieces but the layout is i...
  • schumaku's avatar
    Dec 06, 2020
    That's the perfect moment for adding wiring - a smart decision Double check the wiring and connectors before nice-y-fining things and final paint, e.g. using a notebook computer linking to the router or the Netgrear PoE switch connected to the router.
    I am waiting on some pieces but the layout is internet provider modem to my tp-link smartstream router, netgear poe unmanaged switch and 4 WAC505s on Cat5e cable dispersed through out the 1500 square feet.
    Just wire-up the PoE switch and the WAC505, you can do this on the table with just a patch cable each and one Ethernet ink to your router LAN port to get used to it.
    Make use of Netgear Insight for the set-up and operations - can't be easier. Look here on Youtube: How to Setup a Basic Network | NETGEAR Insight
    You can use your exiting router wireless to do the set-up.
    No need to have a Insight manageable switch, your non-managed is perfectly right. So skip the switch part.
    For the WAC505, you can use the discovery - there is no need for adding serial number manually or use the QR - so use the "Scan Network" as they show for the ReadyNAS. This will show all your four WAC505, and will allow adding these to your site.
    This will set-up all your WAC with the same SSID including seamless roaming.
    When done, connect a wireless device. If everything works as expected, you can disable the router WiFi.
    Can't be easier.
    Enjoy!
ProSupport for Business
