Doober281
Aug 28, 2017Aspirant
How do I remove add-on C from WC7520? for use with wndap360
It would not let me add this question without picking one of the predefined models from the list. However I am using the WC7520 with wndap350 and 360 APs I purchased a used WC7520 to add as a red...
- Sep 05, 2017
I checked the license key on the WC7520 and it was still there. Clicking the refresh button did nothing. I rebooted it and checked it again with the same results. So I went to Maintenance > Licensing > Advanced then clicked the Replace Button. The 10-AP license key was then removed.
Once the license key was removed I Set-up redundancy without any issues. The redundancy failover works beautifully.
Thank you for all of you help with this, it is greatly appreciated!
~Dale~
DaneA
Aug 29, 2017NETGEAR Employee Retired
Hi Doober281,
Welcome to the community! :)
Yes, you are in the right area where to delete the license. You may double-check it on page 152 of the WC7520 reference manual here.
Since the check box is not clickable, kindly try the following steps below:
1. Delete the cache of the browser you are using then access the web-GUI of the used WC7520, then try to delete the license.
2. Use other browsers like Firefox, Chrome, or lower version of Internet Explorer (such as IE7, IE8, or IE9) to access the web-GUI of the used WC7520, then try to delete the license.
3. Use other PC or laptop to access the web-GUI of the used WC7520, then try to delete the license.
4. Disconnect the used WC7520 from your existing network. Since you mentioned that you have already factory reset the used WC7520, connect a PC directly to it. Set a static IP address on the PC that is within the same IP range of the default IP address of the WC7520 which 192.168.0.250. Then, access its web-GUI and try to delete the license.
Hope it helps.
DaneA
NETGEAR Community Team
Doober281
Aug 30, 2017Aspirant
First off thanks for the quick response.
I’m not sure of what happen to the title of my post, but it was supposed to be: How do I remove add-on Licensing from WC7520? For use with wndap360.
Ok so,
- I Isolated the WC7520 from my network.
- Connected directly to it using Chrome browser with cleared cache.
- Reset it to factory defaults again.
And still the check box next to the add-on license key is not clickable. The check box in the header above the actual key is clickable however checking it then clicking delete just clears the check box.
I also tried this with IE 9 on an old XP box with the same results.
When I first received the unit I upgraded it to the latest firmware not realizing that it had an add-on license pack installed. I just wondering if somehow flashing the firmware locked in the add-on.
Is there a reset command that can be issued from the console connection that will clear all information stored on the unit. Because apparently the reset button does not do this.
Thanks!
- DaneAAug 31, 2017NETGEAR Employee Retired
I got the serial number of the 2nd hand WC7520 via private message. However, you have not included the 10-AP license key registered in it. Kindly send it to me via private message as well. I will make a request if its possible to deactivate the 10-AP license registered to the 2nd hand WC7520.
DaneA
- DaneASep 03, 2017NETGEAR Employee Retired
I just want to follow-up. On the web-GUI of the 2nd hand WC7520, go to Maintenance > License > Inventory then click on the Refresh button. Check if the 10-AP license key has been deactivated already. Be reminded that once the 10-AP license key has been revoked, it cannot be undone anymore. Also, check if you can now set-up redundancy on your two WC7520.
DaneA
- Doober281Sep 03, 2017Aspirant
I have checked and the 10-AP license key has not been deactivated yet. Once deactivated I will attempt to setup redundancy again.
As for the extra licenses, I have no need for them. I currently controlling 7 APs and at the most will have 12 well within the limits of the base unit.
Thanks for all your help with this.
- DaneASep 04, 2017NETGEAR Employee Retired
I follow-up with the higher tier of NETGEAR Support and it is confirmed that the 10-AP license key on your 2nd hand WC7520 has been deactivated already. Make sure that your 2nd hand WC7520 is connected to your network that has an internet connection. Then, login again to the web-GUI of the 2nd hand WC7520. Go to Maintenance > License > Inventory then click on the Refresh button. Double-check if the 10-AP license key has been deactivated. Afterwards, check if you can now set-up redundancy on your two WC7520.
DaneA
