Doober281
Aug 28, 2017Aspirant
How do I remove add-on C from WC7520? for use with wndap360
It would not let me add this question without picking one of the predefined models from the list. However I am using the WC7520 with wndap350 and 360 APs I purchased a used WC7520 to add as a red...
- Sep 04, 2017
I checked the license key on the WC7520 and it was still there. Clicking the refresh button did nothing. I rebooted it and checked it again with the same results. So I went to Maintenance > Licensing > Advanced then clicked the Replace Button. The 10-AP license key was then removed.
Once the license key was removed I Set-up redundancy without any issues. The redundancy failover works beautifully.
Thank you for all of you help with this, it is greatly appreciated!
~Dale~
Doober281
Aug 30, 2017Aspirant
First off thanks for the quick response.
I’m not sure of what happen to the title of my post, but it was supposed to be: How do I remove add-on Licensing from WC7520? For use with wndap360.
Ok so,
- I Isolated the WC7520 from my network.
- Connected directly to it using Chrome browser with cleared cache.
- Reset it to factory defaults again.
And still the check box next to the add-on license key is not clickable. The check box in the header above the actual key is clickable however checking it then clicking delete just clears the check box.
I also tried this with IE 9 on an old XP box with the same results.
When I first received the unit I upgraded it to the latest firmware not realizing that it had an add-on license pack installed. I just wondering if somehow flashing the firmware locked in the add-on.
Is there a reset command that can be issued from the console connection that will clear all information stored on the unit. Because apparently the reset button does not do this.
Thanks!
DaneA
Aug 31, 2017NETGEAR Employee Retired
I got the serial number of the 2nd hand WC7520 via private message. However, you have not included the 10-AP license key registered in it. Kindly send it to me via private message as well. I will make a request if its possible to deactivate the 10-AP license registered to the 2nd hand WC7520.
DaneA
NETGEAR Community Team
