Doober281's avatar
Doober281
How do I remove add-on C from WC7520? for use with wndap360
It would not let me add this question without picking one of the predefined models from the list. However I am using the WC7520 with wndap350 and 360 APs   I purchased a used WC7520 to add as a red...
  • Doober281's avatar
    Doober281
    Sep 05, 2017
    I checked the license key on the WC7520 and it was still there. Clicking the refresh button did nothing. I rebooted it and checked it again with the same results. So I went to Maintenance > Licensing > Advanced then clicked the Replace Button. The 10-AP license key was then removed.
    Once the license key was removed I Set-up redundancy without any issues. The redundancy failover works beautifully.
    Thank you for all of you help with this, it is greatly appreciated!
    ~Dale~
ProSupport for Business
