nanorobocop
May 07, 2020Tutor
How to disable SSO login?
Hi here! I'm happy owner of Netgear WAC124 access point. Firmware Version V1.0.4.4 When setup first time I've created netgear account and registered the product. But on next logins it always re...
Pjpj
Sep 10, 2020Tutor
Yeah. I waited too long to return mine so it went into the electronics waste disposal. If I can't have a local login and keep mine and my devices info private, I will just buy a different brand. Which I did. I think Netgear maybe miscalculated on this one.
bizprotech
Mar 03, 2021Aspirant
I'm doing the same, no more NetGear purchases. WHy would NetGear for Business think it's OK to create personal password secrets and force a login to manage their crap. Ridiculous, this is not acceptable.
- schumakuMar 03, 2021Guru - Experienced User
This problem does only apply to the WAC124.
YeZ can this unliked design replaced by a standard Netgear wireless AP version, too?
On the cloud manageable switches where such a similar feature briefly showed up in the second half of 2020, it's no longer required anymore, too.
